Teamwork & BIMcloud
Remote Access to Bim Server
Hi everyone!
i'm new in forum, but not in AC. In my office we work with teamwork and Bim server and it works really perfect but now it's a very useful to connect from off the office. We try to configure everything, create the .twlink but when we go to other internet connection it get an dns error. I've read the article (http://www.archicadwiki.com/Teamwork/BimServerRemoteConnection) and can't understand very well how to access without a vpn conection.
Can someone could explain how to remote access in the simply method ? it´s important also have connection via Win and Mac.
Thanks
8 REPLIES 8
muril00ng
I have this same question, I'm awaiting for help.
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
i also having the same issue here, the BIM server working fine through my office network but couldn't allow me to access from home. i have the right IP address and saw server name appear on my screen but it didn't recognized my username and password which is the same i used in the office. could anyone please help???????
Rob
Guys,
a good start is reading this:
http://www.archicadwiki.com/Teamwork/NetworkSpecification
::rk
Scott Bulmer
Rob - do you know if the static IP address issue cited in the ArchicadWiki Network article you referenced be fixed by using a Client Update Service like that provided by DynDNS.com?
The Dynamic DNS service consists of the user (you) creating a host name and having that host name updated when your IP address changes. This way whenever you want to connect you use the host and not the IP.
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Hi Scott,
Yes, that is the recommended method if you do not have a static IP. See this Wiki article, which has described the DynDNS method since 13 was delivered:
http://www.archicadwiki.com/Teamwork/BimServerRemoteConnection#A-_Using_the_same_Domain_Name_string_...
Interestingly, someone has edited that article to say that using a dynamic domain name is recommended only for testing. I disagree. I do not know of any problems with using it for production. The key is that you MUST use the host name assigned at all times - local and remote - so that libraries will be properly found. Later in that article, it explains how to edit the local hosts file so that the DynDNS domain name can be used locally.
PS The link above depends on the text of the section heading ... which someone might edit again. Just in case, here is the article itself:
One of the forum moderators
vfrontiers
I really only want to be an architect.... So I went and signed up for the dynDNS stuff... only to have my router say TEST FAILED...
All I want to do is have a person at a remote site be able to tap into my BIMServer and see the files and make some comments...
I've read the two articles, but both say things like "there's way too many different routers to list step by step instructions"
So maybe someone's had experience with a NETGEAR WNR 2000 on a MAC system to offer up some suggestions...
As below, working ok over my LAN...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
The pdf for your router is here. http://kb.netgear.com/app/answers/detail/a_id/4448
Section 4-6 or page 70 has steps to get your router working with dynDNS.org Also, looking over the default setup, you are going to have to open ports in your firewall for that the bimserver uses.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
New wiki article in this topic which is worth to visit if you want to remotely access a BIM Server: http://archicadwiki.com/Teamwork/RemoteConnections
Katalin Takacs
