Find the next step in your career as a Graphisoft Certified BIM Manager!
Teamwork & BIMcloud
Role Permissions - internal drawing?
The user's role has permission to create, edit and delete both views and layouts, however they're not able to bring a view into a layout. Which permissions control their ability to do this?
11 REPLIES 11
Hrmmm, after receiving full permission to control elements in the drawing I'm stilling getting the message that my role does not allow me to create the drawings. Any ideas as to what might prevent me from reserving an element even though I have the same permissions as someone else who is able to reserve it?
Erika Epstein
Cleverbeans,
In BIM server role settings>Project structure It sounds like you have " Layouts and Subsets -create" enabled. The next Access down " Layouts and Subsets -delete/modify" should do what you want with an existing layout.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I have that permission set, and I can create new subsets and layouts without issue. I have a drawing that a co-worker brought into the layout and despite having the same permissions I am unable to reserve and edit the drawing but he is. Any ideas on what's causing this problem?
Erika Epstein
You need to ask your colleague to release that drawing(s) to you.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
They've released the object, and the object says "free for reservation" when I hover over it but I am not able to reserve it. I've tried on both a PC and a Mac as well with the same result.
Any other ideas?
Just as a test, I would create a new user with the correct permissions to see if your original user profile has been corrupted somehow.
Any other ideas?
It seems the problem extends beyond just the layouts as I'm no longer able to reserve any objects so it must be that the user profile is corrupt. We had made several changes to the profile over the course of the days so I expect that's what caused the issue.
Thanks for all the help.
I suppose when your Role is changed you do leave the Project and then Join again. This is the way for the new Role settings to become effective.
Also, as I believe Drawings placed on Layouts are actually internal hotlinks, you may want to try the Hotlinks -Manage role setting. Sorry, I don't have the time to try myself.
Thanks Lazlo, I did log out/in after each permission change however it was clear that permissions were not related to the problem I was having once a user with less access was able to do what I wasn't. We created a new profile and deleted the old one which resolved the issue.
