Find the next step in your career as a Graphisoft Certified BIM Manager!
SOLVED!
Roof goodies not appearing
Mimsy
Hi - I'm trying to put tiles on a roof for a construction detail. I thought the best way to do it would be to download the goodies including the Roof Accessories and use the roof surfacer tool. I downloaded the goodies, but when I select the roof and open the design extras, I am only getting the option for adding a ceiling grid. I downloaded the correct goodies for my version of ArchiCAD.
I know Graphisoft guarantee nothing with the goodies. Can anyone suggest where the roof surfacer has gone, or is there a different way to put tiles on the roof? Thanks
AC24 Australia | Windows 10 64 bit | IC3D Workstation, 64GB RAM, 4.9GHz i9 core
1 ACCEPTED SOLUTION
Solution
When you install the accessory goodie, it also creates an 'Accessories' library which you will find the it program folder where Archicad is installed.
You need to load this library with your Library Manager.
2 REPLIES 2
Solution
Mimsy
Yep, that got it. Thanks!
