Collaborate forum
Room Finish inZone Schedule list
ratnabhirud
Hello,
I need Room Finish in my Zone schedule list, but it is not showing in Parameters even it does not exist in Additional Parameters...( Ac 17 )
What else can be done to bring Room Finish in Schedule.
Image attached for reference.
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
2 REPLIES 2
When you select the "Add Object Parameters" button you must then browse the list to find the zone stamp in your library.
Once you select that you will see a list of all the available parameters you can choose from.
Your "Room Finish" should be there but the parameter may not be called "Room Finish" - although it should be something similar.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
ratnabhirud
Thank you Barry very much for your quick reply,
finally found Room Finish Parameter in the list of Additional parameters,
Basically I was searching in the same but it may be missed by me..
Thanks again.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
