2020-06-19 04:59 PM
Solved! Go to Solution.
2020-06-26 12:18 AM
cmartonffy wrote:Hello cmartonffy,
Has anyone else experienced this?
2020-06-28 04:08 AM
cmartonffy wrote:
Using Archicad 23 build 4006 on both machines and BIMserver 2020.1 we experienced dimensions on details that do not update when updated by the team member that created them.
Once the dimension was modified (moved stretched) and then "send and receive" re-executed, dimensions updated.
2020-06-30 11:25 AM
I have never experienced this since 2011. I think you should check your BIMcloud interface to see who is able to do what into your teamwork : "role"
2020-06-30 11:26 AM
So you are saying that one User updates dimensions in his Archicad copy, sends changes to the server, then you receive changes and after receiving changes those dimensions are not updated in your Archicad copy?
2020-06-30 04:28 PM
2020-07-01 04:10 AM
Noémi Balogh
Customer Engagement Expert, Community Admin
2020-07-01 01:35 PM
2020-07-07 03:20 PM
2020-07-18 04:36 PM
toman311 wrote:
So it does seem our office can get all of the dimensions back, as far as we know, by moving the line the dimension is referencing too and then hitting undo or moving it back in its original location. My other teamworks partner decided to just reserve all and move everything over a distance and than moved it back. He said as far as he knows that all of the dimensions came back.
Still, this problem is now affecting us on two projects we use in Teamworks and it seems to affect all drawings. We've seen the problem in Interior Elevations on one project and the Floor Plan on another project in their respective drawing areas.
We also run our Teamwork projects through the 23 BIM Server.
I hope this issue gets resolved.
