2017-07-14 04:47 PM
2017-07-15 06:20 AM
assieh wrote:When you say they are not the same, where they off scale or you are not able to see any content in the dwg. Did you check if the place drawings is selected as "single dwg?" instead of linked xref. See Attached
I would like to save the layout with title blocks into DWG files, however when i open them the do not save the same just the drawings.
I have saved chosen the translator to be in "paper space with cropped views"
