Saving IFC Files From the Plan Window via a publisher set
Is it possible to force AC to save IFC files from the plan window that save elements of the entire building when using a Publisher Set to automate the task. The project is subdivided into 7 files based on element types.
I can do this manually for the whole building, but want to run this at night.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Hi @Aaron Bourgoin , you can try to make all floors marquee around the whole project and save as IFC, i do for quick DWG save.
AC 27 INT 5003 - AC 26 INT 6019 ( For MEP Purposes )
Thanks Mahmood, I don't think the Marquee will help. I can Crete 3D views to automate the procedure, but thought I should be able to do the same thing from the plan window. I have 7 files to Crete each time and want to do this unattended.
Rhino 8 Mac
MacOS 14.2.1
pedrocollares
You may add your 3D views which generate the IFC's to a publisher set directly from the view map, using the Organizer. I always have my IFC's as part of a publisher set.
I'm not sure I understood the issue regarding saving elements of the entire building, you're able to configure your 3D view to show specifically what you intend to save.
Architect / BIM Manager at IDEIA1 - www.ideia1.com.br
Archicad 26 / Windows 10 64
