The zone stamp is an object so it could be used to read information from an external file (Excel) and then place that information into parameters in the zone stamp.
But reading info from external files can get a bit tricky.
The schedules could then be set up to display those parameters.
You would need to know a bit of GDL in order to amend the zone stamp scripts.
You would also need to be careful with the location of the Excel files because if they are in different folders then you will need to tell each zone stamp where to find the file. It is possible to do it automatically if the Excel file is stored in the same location as the PLN.
It is not something you should tackle unless you are comfortable doing a bit of GDL scripting.
