2021-06-09 10:03 PM
2021-06-09 10:47 PM
2021-06-09 10:57 PM
2021-06-09 11:43 PM
Tom wrote:Trick is to create Properties for the owner to fill in then you'll get the info back.
My problem is that room areas and perimeters might change so while the PDF method is easy....it's really not accurate in the long term. Have followed the export via classifications method, but have set up properties so that I can select any item as long as it's included in the checklist for that classification property. The Owner adds something in the exported file that's not one of the property values and I can't import it. Seems like no easy way to do this.
TK.
another Moderator
2021-06-10 02:43 PM
