Schedules slowing down Archicad
Johann_P
Archicad is slowing down, and it seems due to schedules.
Each time I switch a view, even if just between 2 view map plans, I get this "Drawing Status Checking..." notification.
It takes about 20 to 30 seconds each time I switch between view maps before I can work again.
Is there a way to speed things up or to stop this "Drawing Status Checking" ?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
2 REPLIES 2
jfaugustine
Have you tried setting the Update Type to manual in lieu of automatic in the Drawing Selection Settings?
ArchiCAD since 8.0, currently on 22, waiting on 26, maybe...
Johann_P
I have set it to "manual" but I don't see any obvious increase in performance.
What I do find which is really scary is that the schedules do not update when I print.
So I can now very easily issue incorrect drawings.
Let me explain:
As a test:
First:
I changed one of the layers in the assembly.
Second:
I check the sheet where the schedule is placed, and it has not updated even though the wall has.
Third:
I click the update button in the layout book, but the schedule is still not updating, and is still wrong.
Only if I click on the individual schedule, right click, and then click update does the schedule actually update.
Do I have to do this for all the schedules, every time, if I set them to "update manually"?
Windows 10 Pro
Learn and get certified!
