SOLVED!
Scheduling: Only Total of Zone Category
Hello! I want to do a schedule with the Zone's categories grand total areas. Is it possible? I tried to specify on parameters, but it's showing all zones, not only categories.
Prints below (the alterations that i want to do in red)
Hoping it's clear, I'm using Portuguese-BR version.
https://drive.google.com/file/d/1OGCx8hdXg0A8W8BvXlrT-1_q2mO7qcPO/view?usp=sharing
https://drive.google.com/file/d/1ajxG6190bVQjaWfWmxQLHbqOQf8AGRtT/view?usp=sharing
1 ACCEPTED SOLUTION
Solution
JSN
If I understood you correctly you want to have just a summary.
1. Check "Agrupar Items uniformes"
2. Remove the column "Nome Zona" from Schedule Schema
Note: this grouping only works for similiar properties (that's why we have to remove the unique Zone names) and units like length and area, which will be mass calculated.
Hope this is what you want to achieve ...
2 REPLIES 2
Solution
JSN
It worked! Thanks!
The Zone Name column was just for test, but was disturbing it.
