Parametric design
About Rhino & Grasshopper and PARAM-O.
Set size limits in param-o
jc4d
Hello, I'm trying to create a simple cube (to evaluate how flexible param-o is) with only two size options, 1m and 2m but I cannot find a way to do it, if any.
Rajesh Patil
Try this
Hope this is what you expecting.
I have attached one zip file which you can extract and use in Archicad.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Rajesh Patil
Try this
Rajesh Patil
jc4d
Thank you for the suggestion it works as intended.
