SketchUp Plugin
I have read on the SketchUp forum that there are some limitations or difficulties with importing a SektchUp model into ArchiCAD using the plug-in.
We got a presentation of Archicad and I saw the video on this site and it seems real easy. However reading some of the posts I am not so convinced.
5 REPLIES 5
TomWaltz
We've been using the plugin with pretty solid results. What kind of problems did they report?
Tom Waltz
forum.sketchup.com/showthread.php?t=61015&highlight=archicad
Above is a link to one I saw. I cannot seem to find the other.
Will the plug-in really allow you to customize the import? Allow you to assign surfaces as walls and assign components as "smart" objects in ArchiCAD?
Also, if I draw a building with wall thickness', will Archicad change both surfaces into separate walls or can you "tell it" to generate one wall out of those two surfaces? Clear as mud huah
Thanks for the help.
TomWaltz
It runs off a simple logic of
Vertical shapes = walls
Horizontal shapes = slabs
Sloped shapes = Roofs
You can set pretty details translator settings, assigning specific wall materials & types, roof thicknesses, etc, based on Sketchup layer and materials.
In the time it took me to type this, Archicad just imported a 12 MB SKP file.
Tom Waltz
Is there a Sketch-up plug in working for AC10?
Djordje
Ace
To be precise: shapes should have no thickness, no pushing or pulling them.
This means that all the "walls" in sKetchUp should not have thickness, otherwise you end up in Archicad with four walls and two slabs, all of the properties set in the tool at the moment of import. Same for the slabs and the roofs.
So, if you overdo it in sKetchup, a lot of cleanup will be needed.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Learn and get certified!
