Solibri Autorun requires additional xml Information which can be attached to a shortcut or combined in a batch file. However, in AC in the Connection Settings of the Solibri Addon you can select such a "modified Solibri shortcut", however it always jumps directly to the executable and the Autorun is not performed. The batch file is not possible to be selecte and this would also result in IT compliance problems on our workstations.
