2021-02-01 06:23 PM
2021-02-02 01:38 AM
2021-02-02 06:17 PM
2021-02-06 02:46 AM
2021-02-08 09:50 PM
2021-02-10 06:47 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-03-02 07:08 PM
2022-02-08 09:03 PM
SOLVED: I think I had this exact issue with no 'fix". The solution was to literally just zoom in. Above a certain percentage some fields aren't able to be edited. Go figure. What I'd really like to see adjusted is the ability to edit fields if they aren't currently active (ie: change the material of a sill even if it's unactive because there's one shown by default and I want to change them all to be a material listed as "---" when not in use)
