Project data & BIM
Summary of Pens Used
JCCARLOS91
Is there a way of getting a summary or a list of all the pens used in the project? We are trying to match these pens with autocad pen set but I only need to do this for pens used within the project.
is there a way of exporting a list of the pens used?
Any help will be greatly appriecated. Thank you!
John
John Carlos
AC25 | iMac 2019
David Maudlin
John:
You can use the Attribute Manager to see the pens used in the project (I think this also includes pens used in the default settings of the tools). You can export a text file of the pens, but when I did this, the In Use column was empty.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
John:
David
JCCARLOS91
Hi David,
Thank you for the response. This definitely helped.
Thanks for the advice too. Will do that!
John
John Carlos
AC25 | iMac 2019
David Maudlin
John:
Glad to help, thanks for adding your signature.
David
