Collaborate forum
Surfaces won't delete.
Viktorhgo
Hi All,
I'm working on a new template for my office, and I'm working on deleting and updating the surfaces on the template. However, I noticed the file has a lot of surfaces we don't use. And After deleting the surfaces when I open the file again, the file has all the surfaces I just deleted.
Any tips you could help me with?
Certain library objects can create surface attributes.
No matter how many times you delete them they will re-appear when you re-load the library.
Usually you can tell these attributes come from library parts as they will appear with italic text or maybe an underline in the attribute manager.
Tracking down the library part is another matter.
Versions 6.5 to 25
4 REPLIES 4
Steve Jepson
did you remove the unwanted surfaces using the Attributes Manager, Surfaces Menu, Library Manager, or by deleting a .lfc file ?
ArchiCAD 25 3011 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49 Multilight 2.1.0.1
Lingwisyer
Might said surfaces be part of some loaded object?
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Versions 6.5 to 25
I Deleted and clean the library manager and the problem was solved.
Thanks.
