Collaborate forum
Tabulating Floor Sq Ft. from Zones or Fills
I am looking to Automate my Square Footage take-offs that are listed on the plan.
I have figured out a way to show the Zone area in a Table (by dragging the Zone Text into the pre-defined table), but this does not give an Automated Total.
What are others doing to "report" Living Area square footages?
22 REPLIES 22
TomWaltz
The Interactive Scheduler will let you do totals/subtotals.
Tom Waltz
Yes, but are you using it.........
Aussie John
yes good for quick totals on many items including wall surfaces, wall lengths, zone and fill area all totaled and subgrouped by the ID
Cheers John
[/size]
So with little effort I can get the Interactive Scheduler (IS) to report my Living area like the previously attached Table. To report the area with the proper name what element is best to use for this area; Slab, Fill, or Zone?
Most of what I read about the implementation of the Interactive Scheduler is troublesome. It seems that most are saying, "Yeah, the Interactive Scheduler can do that...." But I am not really hearing that people are actually using it this way.
Jay
Aussie John
it might not be exactly as you like but yes the scheduler will give you areas based on the ID - if more than one element has the same id you can set it up to get a sub total
Cheers John
[/size]
Jay
We are using the interactive schedule and I am generally happy with the results. Our door and window schedules come straight out of the schedule and we are workings on a electrical legend. It certainly could have a better interface for setting it up, and sometimes I would like some additional control, but I like it better than my old alternative - export to excel and create a spread sheet.
Aussie John,
It sounds like you have this taped.
How can I get the Schedule to total the "Gross surface of the slab top" field?
Thanks Greg.
Aussie John
Anchor1 wrote:
Aussie John,
Thanks Greg.
click on the settings tab. Click the little square next to the GFA parameter to show the sum symbol. Hope that is descriptive enough.
Cheers John
[/size]
Thanks Aussie John,
I got it to Sum.
Anchor1 wrote:
Thanks Aussie John,
I got it to Sum.
In case others are interested:
The little square "field" next to the GFA parameter only becomes visible once the "Schedule Field" item is selected. In my case it is the "Gross surface of the slab top" item.
see the attached pic.
Thanks Greg.
Would some one please point me to a thread or explain how best to
get the Interactive Scheduler to do the foll:
Total Floor area for example:
First Floor 1000 SF
Second Floor 2000 SF
Third Floor 3000 SF
Total Floor area 6000 SF
At the moment I can get the Floor areas from the individual Slab quantities
in the Interactive Scheduler, but the total is for all slabs on all floors.
I would like it to have automatic updating if the slabs are edited etc.
Thanks Greg.
Aussie John
In the settings (see the previous post image) add an additional parameter (general) of "storey". Once storey is in your list click adjacent to it (in the relative position of the Sigma sign) to get a little flag. Now your areas will be grouped by Storey.
Cheers John
[/size]
Thanks Aussie John, that works great.
Greg.
Jay,
Thanks for responding to my message. With all the help I received, I finally figured out how to make the floor area schedule with totals etc., using Zones.
I am interested in the format of your original posted Schedule. How did you do that? Is your attached pic schedule interactive? How do you set it up to look like that with the numbers justified and pencil lines?
Thanks Greg.
The attached image in the original post was a NON-automated "dead" text schedule. The numbers were entered in manually.
The attached image in this post is of an Automated (being based on zones the zones must be updated if changed.) Element Schedule placed on a layout. This is the current schedule that I am using.
Here is another example of the Schedule. The zones for this example are using the three different zones that I usually use; Heated Space, Non-Heated Space & Decks.)
This post will contain the Screen shot of the Zones.
Here is the Element Schedule
Here is the Scheme Settings
Here is the Schedule placed on a Layout
