2007-01-03 08:47 AM
2007-01-03 06:45 PM
andyro wrote:Andy, they are on holiday 'til the 8th. Mailed Tony Krepler ( tony at cadimage dot co dot nz ) with similar problem. Cannot comment on your TW difficulty.
Also, Cadimage's DWB will not allow users to see the setout tab, even though the library and add-on is loaded correctly, where the setout tab (on the same project even) when opened in SOLO/pln mode. Hmm. Kindof a problem when nobody can modify windows. Anyone else having this problem? I wonder if it has anything to do with the plugin being both mac/pc in the common teamwork environment??/.......
It looks like you have got all the right libraries loaded, so the problem should be one of the following:Further to that 27.12.06
Missing Add-ons – please make sure the following Add-ons are loaded:
Cadimage Update All
Cadimage Image GDX
Cadimage File Dialog
Missing image files. These should have been installed in the Macros folder: ArchiCAD Library 10\Cadimage Libraries\Macros\Mac Imagesü please check if you have folders named Navigator Images and Zoom Images in this folder and they are not empty.
Please make sure Read/Write permissions are enabled on the ArchiCAD Data Folder
Please make sure Read/Write permissions are enabled on all of the folders in the library
Thanks a lot for sending all the details. Please understand our office is closed until 8th January. I need the developers to take a deeper look into the product inside. We will try our best to et back to you with a solution or workaround in the first days of the week of the 8th. I highly appreciate your patience until then.The strange part is that all is in the right place and the 2nd time opening the problem file all is working ok.
2007-01-04 07:09 AM
2007-01-04 07:52 AM
andyro wrote:You can only edit profiles with Exclusive Access, which I think is one of the dumbest ideas. I can see Team Leader, but not Exclusive Access.
I am having a dog of a time managing a small teamwork file, because we are using many profiles that AFAIK can only be modified in exclusive access mode. Why?? A rhetorical statement/comment/question I guess - not to mention all of the other attributes that occasionally need to be modified on the fly. (can profiles be modified as team leader?? checking this now...)
2007-01-04 08:14 AM
TomWaltz wrote:A pretty un-team-like requirement - "OK, everybody, get out of the file, I need to change the zinc flashings to copper..." That's just what I had to do...
2007-01-04 08:24 AM
2007-01-04 08:37 AM
2007-01-04 08:53 AM
2007-01-04 09:17 AM
2007-01-04 11:10 AM
andyro wrote:Andy, do you think it would be decipherable to someone who doesn't really understand window construction yet? I have a hard time with a lot of AC's window objects, but sometimes still find I just can't make them do what I want, especially different shapes. I generally just want fairly basic, schematic-looking things at this point in my career, and want to be able to apply colors and textures to the visible parts and moldings, and to apply different profile moldings, but otherwise, I don't really care about every detail of every measurement.
What DWB CAN do more than makes up for its foibles, but it is increadibly frustrating nonetheless...
2007-01-04 11:27 AM
2007-01-04 10:48 PM
andyro wrote:Andy, I'm a sole practice. And it would happen when wanting to go back and edit. As I said before, for what ever reason it is working at the moment.
Rod, is this TW or SOLO where you don't see the setout data?? ............
2007-01-05 07:09 AM
Rod wrote:Absolutely, not to mention fills, linetypes and whatever else. It should be 'illegal' - GS needs to take a stand on this... also, there is questionable activity in the ArchiCad Data folder that does not get purged/cleared.
Finally it really irritates me to have a 3rd party interfere with my layers.
2007-01-05 05:03 PM
andyro wrote:As it happens with this short break, I thought I'd revisit Cadimage Cabinet Builder for 10. I could not believe that after loading that library
Absolutely, not to mention fills, linetypes and whatever else. It should be 'illegal' - GS needs to take a stand on this... ...........
2007-01-05 05:12 PM
Rod wrote:Such rants need be public, otherwise other poor suckers will stumble onto these problems unawares. It is vital information that hopefully will result in swift remedies. Yes, I am the eternal optimist.
Sorry Andy, turned into a bit of a rant
