Teamwork & BIMcloud
Teamwork log in issues
When opening a file in teamwork, the "sign in" window popped up. Nothing could be done with the file until I signed in. Once I tried to do that, I go the message "You are already signed in! If you abandon your current workspace, you will not be able to send any changes from your recent drafts." Since I couldn't do anything else, I signed in anyway, and it was right - I couldn't changes after that.
I was then told the file could not be found anymore, I had to find it manually. It would let me see the file, highlight it and choose it, but then it would act like I never did that, so after a few futile attempts, I gave up and closed the window. Also, all administrative information was lost at some point in this process.
Has anyone else encountered this problem? Any suggestions how to avoid it?
10 REPLIES 10
Thanks for the info... I hope graphisoft can get this resolved quickly!
