Text field indents in DWG
I am having troubles exporting text fields to DWG correctly, both from version 20 and 22, but I guess it applies to older versions as well.
The conversion seems to dismiss indents in the text field from Archicad - all three, the left and right, as well as first line indent.
Interestingly, the "tab stops" seem to export correctly.
Has anyone came across this issue before?
2 REPLIES 2
Any ideas anyone?
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
I looked into this, and apparently this is an error in our exporter - it doesn't handle tabulation/indents properly (error #261322).
I am afraid there isn't really anything you could do about it for now (unless you use spaces instead to make the offset).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Learn and get certified!
