2019-08-07 04:12 AM
2019-08-07 08:44 AM
2019-08-07 01:04 PM
fuzzytnth3 wrote:Thanks for the feedback. A live palette would be more about making property selections as opposed to just reviewing/reviewing the properties assigned. A schedule does allow propoerty selection but requires the opening of another window/view so the direct reference to the object that is being adjusted is visually lost.
I would just place a label using auto text to display those settings you want the info to show. You could even use "Label Selected" command to label everything. You can then delete the labels when you are done checking. The other way would be to use a Schedule
2019-08-08 12:08 AM
2019-08-08 03:49 AM
2019-08-08 07:19 AM
