2020-08-21 08:25 AM
2020-08-25 01:56 AM
Posednak wrote:it would be helpfull to know how the files are shared.
We work on shared HDD
2020-08-29 01:20 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-30 01:56 AM
mnguyen wrote:There is a setting in AutoCAD that enables xREF load with copy where AutoCAD essentially copies the xRefed file to a temporary folder in your hard drive, if this setting is not enabled the behaviour is exactly the same as that of Archicad
I believe Autodesk applications have a different way to bypass this. Unfortunately, you (or your colleagues) need to close the file before you can start attaching the DWG as XREF.
Best regards,
Minh
