2004-02-16 10:11 AM
2004-02-17 01:57 AM
2004-02-17 04:27 AM
2004-02-17 04:33 AM
Ricardo wrote:If you make a Cube in ArchiCAD using GDL it'll take very few data. If you make a cube in VIZ/max and import it into a GDL-library object, it will be much heavier.
Thanks Stefan for your reply.
Let me see if I got you: Viz hides those edges of a model, they are there but invisible to us. AC doesn´t create more triangles it just shows all the hide edges. Is that right?
Well, I don´t care about looking at unneeded edges, I just don´t want the imported model to be heavier/bigger in AC than it should be.
