Vectoral hatches - can I export these between Archicad files
All,
Is it possible to export vectoral haches that have been created in a specfic AC file for use is floor finishes plans and false celing finishes plans. ?
I have a load of hatches drawn - but how do I send these to another AC file for use in another project ?
See attached - they are in French bit ignore that.
ATF
David Maudlin
atfonit:
You can use the Attribute Manager to send attributes, including Fills, between files. You could also copy & paste the Fills between files, but the Attribute Manager offers more options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
atfonit:
David
perfect thx
