View from Reveal Side dimensions
As you can see in the attachment the View from Opening Side has dimensions by default and View from Reveal Side hasn't. How can I show the dimensions with View from Reveal Side?
How can I add a coverpage to the door and window schedulebook (A4)?
7 REPLIES 7
Gerco wrote:
First of all, make sure that your Linear Dimension Settings are properly set because that is what is going to be used in these Dimensions.
Go to the Schedule, click into the cell and in the Options panel on the left of the generated Schedule check the "Add Automatic Dimensions" checkbox.
You should create it as a separate page (for example in a Worksheet Viewpoint), then place it on a Layout (Or you can compose it directly on an empty Layout). Place that Layout before the Schedulebook's Layout(s) in the Layout Book so when you create a Publisher Set from them it will be easy to create a Publisher Set that contains both the Cover Page Layout and the Schedule Layouts and publish them into a single PDF.
Thank you!
I'm able to show the width and height.
But can I do it also like the attachment?
Erwin Edel
Kubus (the dutch reseller) has extensive tips and tricks for this on their website www.kubusinfo.nl If you have a keymember subscription, you should be able to access their tips & tricks section under support.
Up to ArchiCAD17 I've used the method of creating a list, copying that to a worksheet and adding / altering the dimensions, text etc as needed. It's not a live link to the model though.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Gerco wrote:
Thank you!
No, when you check that checkbox, what you see as a result is the maximum that can be achieved automatically. All other additional dimensions you will need to create manually for each cell in the Schedule.
I recommend that first you make sure that the Schedule fields do not change (you finalize the criteria and the schedule fields), then create custom Annotations in Cells. This is because if you later change the criteria or the scheduled fields, those custom Annotations will be lost and will not come back.
Thanks for the reply's I will look at that.
I have one more question, the opening lines show up fine in the normal view, but in the schedule view it shows the line on the in- and outside trough the glass. So you can't see any difference on the dashed and solid line.
How to fix that?
Since the Views in the Schedule do not have their own Transparency settings, they take the Transparency Setting of the 3D Window.
So go to the 3D Window Settings Dialog and turn OFF Transparency.
Then regenerate the Schedule.
If it still doesn't work (meaning it still shows the Opening Lines both on the inside and outside of the Door), then go to the Model View Options Dialog and on the "Miscellaneous Setting for Library Parts" panel change the Line Type Opening Side and Line Type Opening Opposite Side field from Solid Line to Dashed and vice versa. Then click OK and the Schedule now should display only one of them. of course now you will have to change them both of back once again.
I don't know why this step is needed but it seems like the Schedule recalculates how in needs to display these Opening Lines only when these fields are modified, and not when the transparency is changed in the 3D Window Settings Dialog. This seems to me like a glitch so I will let GS know about it. (Or it may be a technical limitation, we will see.)
Thank you! It works great now
