It can't be done automatically at present. I think there may be a wish for it somewhere on this forum to assist with energy performance calculations. For scheduling my work around was to add a letter marker to the wall ID so you can filter the walls in the selection fields of the schedule. That was a couple of releases ago, these days I may be more inclined to create a custom field with the orientation. I guess it depends how many walls you need to tag whether this works for you. You could use a Graphic Override to check the walls are tagged correctly.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
