Wall Reference Line options failing - GH AC20 Live Conn Mac
Wall Reference Line is not recognized using the Favorites Input Node. The only option available at the moment is Center Line so consider it the Default option at this moment. Tried to use it as a work around due to the fact that Walls remain locked even if it is not the case in the Layer Settings window. Alpha Version.
Issue persists with Beta Version.
0 REPLIES 0
Learn and get certified!
