Wall dimensions without windows and doors
Hi, I am new here, I looked on Google and on the forum but didn't seem to find anything.
Is there a way to get in a schedule the volume and a areas of walls and wall components without subtracting the openings as windows an doors?
Thanks.
4 REPLIES 4
David Maudlin
Francesco:
Take a look at Calculation Units & Rules > Setup Rules... > Reduce Wall > volume by any opening larger than: X and make X a very large number.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks for the reply. Wouldn't that mean that for every schedule then the openings were ignored? What if I only needed it on one?
I found that it's possible for some objects to add gdl parameters and make it perform calculations, but I got it working only on Zone Stamps, while for walls I didn't find a way to add custom gdl parameters using the object editor (cmd+option+O).
I'll add a signature, in the mean time, I am using ARCHICAD 20 on macOS Sierra.
In the interactive schedules you can list the gross, net and conditional surface areas.
Gross is the area regardless of opening.
Net is the area less all openings.
Conditional is the are less openings that exceed the settings in the calculation rules.
Have a look in the reference guide for full explanation (approx. page 1410).
You are looking for "Element Listing Parameters in the Interactive Schedule" in particular the section for "Wall Listing Parameters".
David Maudlin
GDL can be used on Library Parts (Objects, Doors, Windows, Zones, etc.), but not on the built-in building elements (Walls, Slabs, Lines, Arcs, etc.).
David
Learn and get certified!
