2022-12-06 12:05 PM
I'm looking for the right setting to export from Archicad to IFC and import it to Revit.
I have a hosted door&window in a wall. when i import this wall to Revit i got an element the behave different than the same element without a door.
as you can see it's like a model in place extrusion without all built-in Revit parameters. also, this wall in not function anymore as room bounding.
see the same type of a wall without door behave perfect.
hope its clear
2022-12-06 01:10 PM
I found the right setting.
now i have only a problem with windows.
windows doesnt host properly in the wall. when i move the wall the windows stay at the same place.
also, the wall with a windows some reason lost his type
