I have created a custom Graphic template for a Dorr/Window template. I have modified and saved it yesterday, but today AC can't seem to find it. In the "Set Up List Schemes" window its name appears as dimmed but I can't find it.
Doing a search with Spotlight with the Template's name the file that comes up is "New grafpa db. LIS" which is my custom database. Are the Graphic Templates saved in there? And why isn't it loaded?
Can I save them as separate .TXT files? I find some .TXT inside AC library > Templates > List Templates. I suppose those are the same...
I am assuming you are referring to the List Elements schedule, not the Interactive Schedules. I believe they are stored in a file named LISTSET.TXT, and should be in one of your loaded libraries. You might want to make sure that all the libraries you have been using are loaded. Also, there may be problems if more than one of these files is loaded.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
