2019-08-19 01:51 AM
Solved! Go to Solution.
2019-08-20 02:29 AM
2019-08-19 02:40 AM
2019-08-19 03:11 AM
Barry wrote:Dear Barry,
Not that I am aware of.
Just because a layout page is not in a Publisher Set does not mean that it is not being used.
It could be printed directly from the screen (FILE menu > Print).
I don't use the revision and issues systems - so not sure if there is a way to list an index of current layouts.
2019-08-19 04:07 AM
2019-08-19 05:06 AM
Erwin wrote:Dear Erwin,
I think you mean Master Layout, you can select 'tree by master layout' at the top where it generally defaults to 'tree by subset'.
2019-08-20 02:29 AM
2019-08-20 03:07 AM
Erwin wrote:Erwin,
The Master Layout in use has a fold down option
Those without the option are not currently in use.
