Collaborate forum
Which layout sheets are in use?
Karol Argasinski
Dear all,
I have a question regaqrding Layouts in Layout Book. Is it possible to see which layouts are in use (for example as you can do with attributes manager)?
Best,
Karol
OPENBIM does works!
Currently: ArchiCAD 22/23/24/25
AMD Ryzen 7 3700X
32GB RAM
GeForce RTX 2070
Windows 11 Pro
MBP 14 M1 Max 32GB
http://www.bimfaktoria.pl/
1 ACCEPTED SOLUTION
Solution
The Master Layout in use has a fold down option
Those without the option are not currently in use.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
6 REPLIES 6
Not that I am aware of.
Just because a layout page is not in a Publisher Set does not mean that it is not being used.
It could be printed directly from the screen (FILE menu > Print).
I don't use the revision and issues systems - so not sure if there is a way to list an index of current layouts.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Karol Argasinski
Dear Barry,
Thank you for quick response. What I meant is Template in Layout Book. Polish meaning of Layout and template is very simmilar, thus I made a mistake.
OPENBIM does works!
AMD Ryzen 7 3700X
32GB RAM
GeForce RTX 2070
Windows 11 Pro
MBP 14 M1 Max 32GB
I think you mean Master Layout, you can select 'tree by master layout' at the top where it generally defaults to 'tree by subset'.
www.leloup.nl
Windows 10 Pro
Karol Argasinski
Dear Erwin,
That I know. My question is, is it possible in ArchiCAD to see which templates are used and which are not?
OPENBIM does works!
AMD Ryzen 7 3700X
32GB RAM
GeForce RTX 2070
Windows 11 Pro
MBP 14 M1 Max 32GB
Solution
www.leloup.nl
Windows 10 Pro
Karol Argasinski
Erwin,
That was too simple for me obviously
Thanks Mate!
OPENBIM does works!
AMD Ryzen 7 3700X
32GB RAM
GeForce RTX 2070
Windows 11 Pro
MBP 14 M1 Max 32GB
