Collaborate forum
Why can't I use this expression in a GO?
Mats_Knutsson
I have an expression resulting in a string value valid or non_valid. I can't use it in my GO though. I can't even see it when adding properties to the GO rule. Why so?
Br,
Mats
AC 25 SWE Full
Some parameters (and expression-based Properties using them) are not available as Graphic Override criteria:
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70274&p=313988&hilit=graphic+override+para...
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
4 REPLIES 4
runxel
Ace
It seems only Expressions that only use the "general parameters" can be evaluated in a GO.
Smells like a bug (by design) to me. At least it should be available when we set the "element type" in the GO to the right type...
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Mats_Knutsson
Thanks Lazlo!
I'd like to ask GS if it is my job to accidentally find these "not available" properties/parameters?
AC 25 SWE Full
Probably not, but if you do, it is appreciated.
