Window Configuration - Adding a Double Door
Hey Guys,
Using CADimage window maker, I want to add a double swing door in this window configuration (which is easy), however I need to make one door smaller then the other. Not using door maker as the window maker gives me options with the overall window configuration.
Not sure where I can do this in the settings. Using AC 21
anyone know how to do this?
Thanks in advance.
(P.S - emailed CADimage with no reply yet, so thought I'd ask the good people here)
1 REPLY 1
Gerald Hoffman
I don't see an attachment of what you are trying to create. Could you post again?
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
