Window Schedule reading in 64ths of an inche
Hi:
Why do the windows in my window schedule randomly read in 64ths of an inch even though they are specified in whole inches? For example a 3'-1" wide window in plan (and per window settings dialogue box) will read 3'-57/64" in the window schedule?
My project preferences may be set to 1/2" and no smaller.
thanks
6 REPLIES 6
David Maudlin
Don:
Occasionally, my Window or Door Schedule will loose its proper Dimensioning setting (in the View Settings for the Schedule). I have found changing the Dimensioning setting to another Dimensions Preference, closing the View Settings, then changing it back resets the correct Dimensioning setting.
HTH,
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Hi David:
Thanks for your reply! Could you maybe post a pic of the View Settings that you are referring to? My brain can seem to find it,
thanks,
Don
David Maudlin
Don:
See attachment.
David
Hi David:
I didn't see an attachment?
thanks,
Don
David Maudlin
Don:
The attachment only shows up for me if I am signed into the forum (I don't know why this is in this case, normally the attachments show whether I am signed in or not). The setting is View Settings > 2D/3D Documents > Dimensioning.
David
Hi Dave:
I do finally see the attachment. I only found the window by right clicking. but
I didn't see it any other way.
thanks!
Learn and get certified!
