Window Schedules "double letter" how to sort to the end?
rob2218
how do I get the 'double lettered' window tags to show up at the END of the list schedule?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
So, here's the solution for your specific case:
Open Property Manager and create a new property for elements of type Opening by clicking the "+" sign as shown below. I've called it ID_Length, but whatever. Very simple formula. After you click Expression, you can pull in the Element ID field name and from the list of available text expressions, find the LEN("text") function ... resulting in LEN(Element ID). Finally, make the property available to all Windows. (Maybe you want this with Doors too?)
In the schedule itself, you can now find the dynamic, calculated property that you just created (ID_Length) and add it to the schedule just prior to the ID field in the schedule. Sort ascending by that first... then the ID. Finally when you're happy with the result, shrink the column size for the Length field so that it doesn't display in the schedule.
One of the forum moderators
15 REPLIES 15
Try adding a space or underscore character (or maybe some other character) in front of the single letter.
It is the same with numbers
1,2,3,...9,10,11 needs to be 01,02,03,...09,10,11
Archicad simply orders based on the first character.
rob2218
thanks Barry,
will give that a shot.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok Barry, I've tried to add a "period", a "space" an "aesterick" and nothing seems to push the double letters to the back. I'm stumped.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Just tested and a period or underscore (but not a space) in front of the single letters keeps them at the top, pushing the double letters to the bottom. Unfortunately, you have to look at the period or underscore in the schedule and any labels that contain the ID.
The other old, tried and true method is potentially error prone due to data entry error and changes and relies on manually entering a sorting code in an extra field of the library part. You use that sort code, perhaps combined with the ID, to sort the schedule, but change the column width so it doesn't show.
For your particular case ... single vs double (and maybe triple etc) letters ... the relatively new Property Expressions are the best solution. You get your cake (the ID's look the way you want everywhere with no funny extra symbols) and get to eat it too (the sorting is your way).
Will start a fresh post for the details - but the idea is you create a new property for openings - and the value of that property is the length, in characters, of the ID string: 1 for "A", 2 for "BB". Then, your schedule includes THAT new property as the first sort, and the ID is the second sort. Thus, all 1 character IDs will be grouped first, then 2 character IDs, etc.
Just to add one thought to Karl's solution:
If you create this Schedule in a way that the "ID_Length" field is the first, then it will be at the left side (or top ) of the generated schedule.
Then, you can save a View of it and place that on a Layout as a Drawing.
Then, you can adjust the frame of the Drawing so the Schedule Column/Row showing the "ID_Length" field does not show.
rob2218
So...here's as far as I got?
I'm not sure how to go any further than here......
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Seems the "ID_Length" parameter is greyed out in my ability to add any numbers inside that field? I'm not sure what did wrong.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
here's where I'm getting stuck. Beyond this point...whenever I try to type LEN or anything...I get some sort of syntax or formula error.
i>u
Edgewater, FL!
SOFTWARE VERSION:
