I have created a door and window list, with the automatic dimensions clicked on, but it is not showing. Even if I unclick it and switch it back on, noting happens. When I put other dimensions n the annotation mode in, even that doesn't show. I have created a new list but still it is not working.
What am I doing wrong? I am working on AC24.
Thanks
it is most likely program bug. There is no hidden settings for automatic dimensioning there - they can be or on or off - I'm quite sure you are doing everything correct. What you can try - open or create another file and test it there. Also you can try open and repair function.
Maybe restart ArchiCAD.
It seems that it could be a bug with the model. I have tested with another model and it works perfectly on that one. I have tried the open & repair function on the said model, but it is still not working. Luckily I don't have a lot of new windows and doors, so I made a plan for now.
Thanks for all the effort.
What happens if you delete the Schedule Scheme, and then recreate it from scratch? Do the Automatic Dimensions appear then?
Is this by any chance a project migrated from a previous version?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
