Window/door schedule
Hi
I have been reading a lot of posts but can't seem to find the solution to my problems.
I am making a window and door schedule and I was wondering:
-if there is any way to automatically dimension not only the total size of the door/window but also the frame size and space in-between?
-is there also a way to display the real height of the window to project zero?
(in the window schedules all the windows/doors are at 0.0 height no matter which floor they are at)
thanks a lot
2 REPLIES 2
Yes but only the overall dimensions (so long as your objects have been scripted properly to do this).
The frame dimensions you can do by choosing to 'Annotate' the image.
I don't think there is a way to automatically dimension the sill heights but you should be able to get them to display in relation to the story or project zero.
You can schedule the sill and head heights if you select those fields to be included.
Learn and get certified!
