2015-01-05 10:09 PM
2015-01-07 04:02 PM
2015-01-07 04:09 PM
2015-01-07 04:11 PM
2017-09-08 11:30 PM
2020-06-21 05:11 AM
2020-06-30 05:10 AM
paborges wrote:Hi Pedro,
Dear All,
I was wondering if you could help me with this issue. I am having the same problem, I can see all the information on the Xref manager, but I can't see the drawing. When I import it, I can see the rectangle showing the drawing size, but after the importation is finished, I can't see anything. I have already tried to open a new Archicad file and I have already tried many different AutoCAD files. However, I always have the same problem. Therefore, I think it is not a file problem, but maybe I am importing it incorrectly.
The dwg file is in meters, so I set the Archicad file in meters as well. When attaching the xref I leave the scale X and Y = 1 and in the translator settings, I change the drawing unit from millimeter to meter.
Could you please help me with this problem?
I can place the external content without any problems, reinforcing that it is not a file problem, but possibly a process matter.
Thank you very much,
Pedro
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-12-03 10:51 PM
2020-12-03 11:10 PM
toniski wrote:Hello,
Thanks! I had the same problem, and yes, the xref is all on New Construction Renovation Filter. But then how to change the Renovation status of an XREF?
Minh Nguyen
GRAPHISOFT
