2016-01-12 11:49 AM
2016-01-12 12:25 PM
2016-01-12 01:01 PM
2016-01-12 02:41 PM
2016-01-12 02:49 PM
Alex wrote:Ok, that sounds promising.
From what I remember, you can place a for next loop inside the mesh command ...
2016-01-12 02:54 PM
2016-01-12 02:58 PM
2016-01-12 03:04 PM
Erwin wrote:I'll get back to this tomorrow. The original land survey .asc files are quite big, but I've made a small one to be tested with GDL object. I can send that one.
Can you share the esri ascii file here? I have QGIS installed, can have a look if it works.
2016-01-12 03:16 PM
2016-01-13 09:24 AM
Alex wrote:I tried to google this, but couldn't find any references. Somehow it seems strange to be able to place FOR...NEXT inside MESH - or any other - command. I might be wrong. But while searching I found this:
Then use get nsp or so for the values
Erwin wrote:Yes; the .ASC text file is 69 MB.
But it sounds like you have a LOT of values to work with.
Erwin wrote:I checked the link, and it seems QGIS can do it. I tried this (from the linked page):
From what I'm reading GRASS should be able to export the imported raster to xyz.
I'm using Windows 7 version of it.
http://gis.stackexchange.com/questions/45197/what-is-xyz-format-in-qgis
