Collaborate forum
Zone Areas with Multiple Hotlinks Scheduling Multiple Times
I am working on a project with a lot of hotlinks. We use zones for our area calculations per floor and I have placed them in the mods. We schedule the Calculated Area per Level in our base file but since I have 10 of a single type of unit it schedules the Calculated Area separately 10 times. If I turn on Merge Uniform Items, the Calculated Area sums up all similar items. i.e. First Level is 297sf (scheduled 10 times) and with Merge Uniform Items is changes First Level to 2,970sf (one time).
Is there any way to Merge Uniform Items and not have it sum up the Calculated Area so that First Level reads 297sf once? A work around would be to place one of the zones per unit in the base file on a no plot layer and adjust my schedule settings accordingly but I'd prefer not to do this if there is another way.
2 REPLIES 2
Eduardo Rolon
If you have different Master Layer (the one you assign when you place the hotlink) for the hotlinks then you can filter the schedule for only one of the Units.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC26 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2023
Or you can define different Master IDs for the different placed Hotlinked Module instances and filter one of the modules by the contents of its ID when scheduling it. In that case the Hotlinked Modules can be on the same Layer.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
