Sorry for some reason I read your post as 'Complex Profile' wall rather than 'Composite' wall.
I was wondering if the shape of the complex profile was causing the problem.
This is clearly not the case and I can see nothing unusual about your composite wall.
Do you have more than 2 zones (one each side of the wall)?
When there are multiple zones doors and windows can have trouble determining which ones they belong to.
Also check that the zone extent is stretched right up to the side of the wall - not stopping short and not going past the side of the wall.
The wall with the pocket door is much wider than the other wall where you say the zones are working.
I am wondering if the zone is not touching the sides of this wall.
