One thing to check is that your zones have a height and are not set to zero.
I just tried (I use different doors to you - my own objects).
I had zone heights of zero and schedule only showed the 'from zone'.
I adjusted the zone height (had to be at least half the door height for some reason) and then the 'to zone' started working as well.
