LopoJr wrote:
I am trying to find the additional parameters you mentioned in AC18 but I can't find it. Is the "cost/m2" function still available in AC18?
Also, is it possible to multiply in AC18 or is that sill not an available function?
In 18 it is set out a little differently.
You have to press the triangle button next to the 'ADD' button (see image).
Then choose 'Add Object Parameters' and then find the object and parameter you are after.
As for calculations in the schedules - no.
You can only do simple totals and counts.
You can script objects to do calculations within themselves and have them update a parameter in the object.
Then list those parameters in your schedules but you will need a little knowledge of GDL and it only works for objects - not elements such as walls and slabs.
