If the zones are only for extracting area and volume information, then I don't see a problem, as Djordje says.
But, if you plan on creating schedules that indicate what zones objects are in (furnishing schedule), or into which zones doors swing, etc. ... then you will have a bit of a mess.
ArchiCAD keeps track of the multiplicity of zones, and using SQL or ODBC, you can extract and display the complete list of overlapping zones that an object resides in.
BUT, within ArchiCAD itself - the Interactive Scheduler for instance - there is only one zone field. It is a game of roulette which zone will be reported when there are multiples from what I know a the moment.
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
