Zones;
Hello,
Iam working zone lists and i have few questions,
This is what I got now : 1. I would want to have sum by zones category, (for example : adminstrative zones 200m2 and other zones 50m 2, Sum of all 250m2)
2. I would want to change font of text to fit other drawings
3. After I finish everything how should I place it on layout next to each floorplan layout.
Thank you in advance
6 REPLIES 6
This post may help you with the grouping.
https://archicad-talk.graphisoft.com/viewtopic.php?f=34&t=67423
Of course you will need to be listing the category in the schedule.
Sorry I can't tell if you have that or not as I don't understand your language.
2).
To the left of the schedule page, you will see the settings that control font, style size, colour, etc., for each cel or group of cells.
You just choose what you want the settings to apply to and then make the changes.
3).
You save a view of the schedule, just like you do for plans and elevations.
You then add this view as a drawing to the layout next to your floor plan.
This is what I got, but i cannot change some thigs that I dont need.
I dont want to show room height, wall surface and floor type.
I copied scheme, amd when i go into settings, start format wizard i cannot find where to shut it down, no matter what i turn on or off it stays same.
Also i didnt find font settings
Sorry, you are talking about lists - I missed that bit.
I was referring to the Interactive Schedules.
I haven't used the list in about 10 years.
Is there any reason you are not using the schedules?
I cannot find interactive schedule, only list
Hello,
I succed to create interactive schedule, now I onyl dont know how to have sum of unit areas and then sum on units on floor.
I don’t have ArchiCAD with me at the moment, but Rex had a good image in the post I originally linked too.
Set the ‘sum’ option next to the fields you want to sum, set the flag next to the field you want to group (category?) and set to show the headline.
Barry
Learn and get certified!
