2020-09-02 09:35 AM
2020-09-02 09:38 AM
2020-09-03 06:28 AM
2020-09-06 08:59 AM - edited 2021-09-16 11:20 AM
1. With the Schedule generated, activate the "Options\Project Preferences\Dimensions..:" Dialog and set the Linear Dimensions to the desired format (for example, zero feet to be displayed).
2. Save changes under a new Dimension Settings name.
3. Click "OK". The Schedule should update.
4. Save a View of the Schedule so it will store the Schedule with the Dimension Settings you saved. Otherwise, it will always apply the Dimension Settings of the last Viewpoint you were in, which may not be the settings you need.
5. If you want to generate the Schedule later, double-click the saved View to make sure the proper Dimension Settings are applied to it.
Additional tip: Use the "Window\Palettes\Quick Options" menu command to display the Quick Options Palette, which will show which Dimension Setting is currently active.
2021-09-16 12:40 AM - edited 2021-09-18 05:11 AM
