archicad 23 dwg opening problem
I have a problem with Archicad 23 commercial license: when I open any dwg-s the file is simply empty. It contains the layouts but does not contain any lines of fills or anything. I am working on a mac.
I can perfectly open dwg files with Archicad 22, but not with Archicad 23.
Do you have any idea how to solve it?
Thanks in advance.
Best,
Eszter
1 REPLY 1
Is it a Renovation Filter problem?
I know there is an issue when exploding DWGs …
https://archicad-talk.graphisoft.com/viewtopic.php?f=22&t=69419&p=308845#p308840
Try changing to a Renovation Filter that shows everything.
(I have no idea if that is the issue).
