archicad to autocad and back
Hello.
I am trying to export a file from archicad to autocad. Is it possible for the .dwg to contain the same amount of info as the .pln file? I would like to export not only the 2D (dimensions, writing, walls in 2D etc), but also the volumes. Also, is it possible to import a file I exported into Autocad back to Archicad with both 3d and 2d info?
Do Merge/Smart merge help in any way?
Thank you.
1 REPLY 1
No need for an answer any more.
Learn and get certified!
